hallo,
ich habe alle möglichen Einstellungen ausprobiert, damit die Kühlung funktioniert, aber ich finde es einfach nicht heraus
ich habe keinen separaten Kühlpuffer
Einstellungen:
7100 = 3
7103 = 20 (wenn ich ihn auf 18 einstelle, erhalte ich Kühlwasser von 14°??? also verstehe ich die Bedeutung dieses Parameters nicht)
7105 = 1
7107 = 10
7109 = 0
7117 = 1 (ich habe allerdings keinen Sensor)
die gewünschte Raumtemperatur beträgt 21°.
die tatsächliche Raumtemperatur beträgt 24°.
die aktuelle Außentemperatur beträgt 26°.
Warum startet die Kühlfunktion nicht?
Mit freundlichen Grüßen
Marc
Übersetzt mit DeepL.com (kostenlose Version)
HI Dr Who!
The name should be "Doctor Who". Anyhow, that is not really much information to guess. There are many reasons why the cooling might not work as expected. One of them, and may be the most likely one is that the dew point sensor measuring the condensation of water on your heat pipes is activated and shuts down your active cooling.
The other reason is, that the control of active cooling is using the same hysteresis as the heating - which is +2K for on and -4K for with standard settings. This means, that the cooling starts with measured temperatures in the secondary circuit of 22°C and cools down to 16°C which is often already below the dew point. The problem here is that the hysteresis is just to large to allow for an effective cooling.
However, reducing the hysteresis is not so simple and requires some knowledge, since it requires to switch between temperature sensors, which in return requires further adjustments to the heating and cooling characteristics. But even after this change it is unlikely that you reach 21°C with a active cooling system, because it is just not an AC and missing the major effect of dehumidifying.
Anyhow, my suggestion is to ask your installation company to fix the issue and setup the cooling sufficiently.
Best regards
Gwyn
Hallo DrWho,
7103 gibt zwar die minimale Vorlauftemperatur an, er begrenzt damit aber lediglich den Sollwert. Aufgrund der Ausschalthysterese kann die Vorlauftemperatur auch niedriger als der hier eingestellte Wert sein.
Gerne kannst du einmal Bilder von jeder Seite der Anlagenübersicht posten, wenn du der Meinung bist, dass die Kühlfunktion starten soll. Du gelangst dorthin, indem du die "?"-Taste ca. 4 Sekunden gedrückt hältst.
Die Kühlfunktion startet, sobald die Kühlgrenze überschritten wurde.
Kühlgrenze = eingestellte Raum-Solltemperatur + 4K
Kühlbetrieb aktiv: Langzeitmittel Außentemperatur (3h) > Kühlgrenze
Kühlbetrieb inaktiv: Langzeitmittel Außentemperatur (3h) < Kühlgrenze - 1K Hysterese
