I do not know the reason, but my previous comment was changed by your system (missing/changed words), I am sending it again:
Thank you for your feedback.
Temperature for hot water is shown correctly in control unit (compared with thermometer on boiler itself).
Problem is that hot water is not prepared in time interval set in control unit, nor by using party option.
The only way, how to prepare hot water is by using of standby mode option (leftmost option on upper rotary switch - weather-compensated mode with standard programming unit) or by Reduced room temperature option. In this situation the hot water is prepared, but regardless of the temperature limit set by the control unit hot water has always 75 degrees Centigrade.
Thank you for your assistance.
Best regards.
