Hello, I would like to report a communication issue between my heat pump (Vitocal 151-A AWOT-E-AC-AF 151.A16) and the ViCare app. Although the equipment is connected to the local internet network, the app reports that the system is offline.
Previzualizați atașamentul 20260803_234343.jpgPrevizualizați atașamentul 20260803_234343.jpg
@Mihai_Draghici please configure your router in the way that the router always will assign the same ip-address to the vitocal.
@Lacotiv I already assigned the heat pump a static ip address (192.168.68.53).
There is/was a similar problem reported some days ago, where the vitocal is connected but you can not address it with the app:
https://community.viessmann.de/t5/Waermepumpe-Hybridsysteme/Keine-Verbindung-zum-Internet-APP/td-p/6...
Maybe should @Viessmann Support Team take a look if there is a problem in the backend...
