VITOCAL 200-G BWC 201.B13 soft start option
Hello,
I have a VITOCAL 200-G BWC 201.B13 heat pump.
I see in the specification that my heat pump doesn't have a soft start.
Option 1 - Is it possible to add it from the Viessman component for my heat pump? If yes, can you share the component number?
Option 2 - Or maybe i can add soft start from market like:
My goal is to lower starting current (compressor) to use a gas power generator in emergency situations.
Regards,
Christopher
1 ANTWORT 1
Hello Christopher,
Your Vitocal 200-G BWC 201.B13 heat pump should have a full shaft soft starter. This has the order number 7828824.
Many greetings Flo
