Vitodens 200 WB2 hot water not prepared as result of reset of control unit.
Vitodens 200 WB2 hot water is not prepared by time, nor the Party option. Only way, how can I prepare hot water to switch off option - control unit behave in a reverse way.
Thank you for assistance.
did you checked the resistance of the hot water Sensor? Whitch temperature for hot water is shown in the control unit?
Kind regards °pa
Thank you for your feedback.
Temperature for hot water is displayed correctly in control unit (compared with thermometer on boiler itself). Problem is, that hot water is not prepared in time interval set in control unit, nor by using Party option. The only way how to prepare hot water manually is by using standby mode option (leftmost option on upper rotary switch - control unit for weather - compensated mode with standard unit) or by Reduced room temperature option. In this situation the hot water is prepared, but regardless the temperature limit set by control unit (I have set 55 degrees Centigrade), hot water has 75 degrees Centigrade.
Thank you for your assistance.
Best regards.
I do not know the reason, but my previous comment was changed by your system (missing/changed words), I am sending it again:
Temperature for hot water is shown correctly in control unit (compared with thermometer on boiler itself).
Problem is that hot water is not prepared in time interval set in control unit, nor by using party option.
The only way, how to prepare hot water is by using of standby mode option (leftmost option on upper rotary switch - weather-compensated mode with standard programming unit) or by Reduced room temperature option. In this situation the hot water is prepared, but regardless of the temperature limit set by the control unit hot water has always 75 degrees Centigrade.
Best regards.
