Yes, at Loren line, the device was purchased.
Through Viessmann's website
www.novogrejanje.com, I filled out a form and received a recommendation for the Vitocal 100-s 8kw and the installation company Loren line, installed and put into operation 16/01/2017.
Due to frequent shutdowns of the heat pump, due to a high pressure error, my outdoor unit was replaced with a new one on 10/02/2018.
When the repairers came, to my question why the circulation pump does not modulate its operation, I get the answer that it is a highly efficient pump .... ok but, no one to check its operation and make sure it is 100% constant work, without modulation.
https://imgur.com/0TrLK8Fhttps://imgur.com/uAFdcBK
