Viessmann Vitocal 100-s
Hello, I have a Viessmann Vitocal 100-S, 8kw heat pump. The installation scheme is 6, with 2 heating circuits, a hydraulic switch and hot water heating. In coding level 1, I do not have the 7340 option, and cannot change the circulation pump operation. The pump is always 100% running and 50% 2minutes the compressor goes off. What does the "TEST PUMP" at the circulation pump mean? I am sending you pictures of the pump and installation. Best regards.
https://imgur.com/4bxffAU
https://imgur.com/mXlOGD1
https://imgur.com/0bdZz3D
38 ANTWORTEN 38
Mr. Flo, here's a video of DHW high pressure shutdown. The heat pump was DHW heated, **bleep** defrosting and returned to DHW warming, high pressure error and shutdown.
The hot water boiler has a 4m² exchanger, and as seen in the video, the circulation pump does not modulate its operation, but is constantly operating 100%.
Parameters 6021, 6022 and 6023 have no effect on the circulation pump when DHW is heated.
https://youtu.be/X9wuePGoI8w
Best regards
Miloš
Should write "**bleep**",I don't know why it write **bleep**
Er sollte danach schreiben, ich weiß nicht warum er schreibt **beep**
Did you buy your heat pump from loren line?
Your system should be checked by a service technician.
Best regards °fl
Yes, at Loren line, the device was purchased.
Through Viessmann's website www.novogrejanje.com, I filled out a form and received a recommendation for the Vitocal 100-s 8kw and the installation company Loren line, installed and put into operation 16/01/2017.
Due to frequent shutdowns of the heat pump, due to a high pressure error, my outdoor unit was replaced with a new one on 10/02/2018.
When the repairers came, to my question why the circulation pump does not modulate its operation, I get the answer that it is a highly efficient pump .... ok but, no one to check its operation and make sure it is 100% constant work, without modulation.
https://imgur.com/0TrLK8F
https://imgur.com/uAFdcBK
How did you stay with Loren Line?
Best regards °fl
I stand with Loren Line, ok. Installation is ok, the only problem I have is with the Vitocal 100-S, such as not having the codes listed in the manual (7430). I contacted Viessmann Serbia, I expect their technician to come and inspect the installation and heat pump. I will inform you what is up when the technician arrives. Best regards
Code 7340 not 7430, my mistake
Mr. Flo, what does this symbol mean in diagnostics?
https://imgur.com/tfwV16K
Best regards
Miloš
What is the function of the code plug, does it affect the software version and code availability at the coding level?
If the symbol flashes, the defrost is active. The control software is not changed via the coding plug. He is responsible for adjusting some parameters that are directly necessary for the operation of the outdoor unit and the cooling circuit.
Best regards °fl
Please Mr. Flo, do these two videos give you a clearer situation, defrosting or something else, like an oil return?
The compressor raises its capacity to 75%, during normal operation, **bleep** 3 minutes resumes normal operation.
https://youtu.be/3e_ahg8cowY
https://youtu.be/eNXQdvbATMc
Best regards
Miloš
Mr. Flo, what code determines how long **bleep** a defrost the compressor will operate at increased power? I see it lasts 3 minutes.
Best regards
Miloš
Hello Milos,
the drop symbol with the two arrows means that the oil recovery function is active.
Defrosting is always active at least until the necessary evaporator temperature has been reached. This can also be seen in your video.
Best regards
