The parameters that govern the speed adjustment of the secondary pump during DHW are 6020, 6021, 6022 and 6023. However, this requires that parameter 7340 is set to 4. Since you cannot access it, you have to check whether it works or not.
6020: 3 - Speed-controlled operation, control via PWM
6021 - Min. Output storage tank charging pump
6022 - Max. Output storage tank charging pump
6023 - Nominal output of the primary store pump
Best regards ° fl
