Hi, I have Vitocal 222-S heat pump in a combination with Vitotrol 200 as a remote control.
Hi, I have Vitocal 222-s with Vitotrol 200 as a remote control. Please let me know if it is possible to fine tune these two in order to achive the desired goal, constant temperature in a living room? For example, the desired temperature has been set to 23 degrees, Vitotrol 200 shows that the temperature in the living room is 24 degrees but the heat pump continues working!?  Is there some other "remote controler" which is recomended to be combined with the Vitocal 222-s instead Vitotrol 200? Thank you very much for your fast response.
Regards,
Vladan Radosavljevic
1 ANTWORT 1
Hi Vladan Radosavljevic,
do you have a mixed heating circuit with an external extension? If yes, you can configure a fixed room temperature in combination with Vitotrol 200.
Kind regards, °ch
