Opentherm for vitodens 200
Hello,
I want to add opentherm to my installation.
I have a vitodens 200 with Vitotronic 200 combined with a solar installation.
On the net I read that the possibility exists but what module or extension do I need?
Kind regards
5 ANTWORTEN 5
Hello Pak0,
what do you want to control? A signal from Open-Therm to Vitodens 200?
In Canada and USA there are KM BUS and Open Therm connections. That's an extension kit for heating circuit with mixing valve. But only for main power supply 120V
Kind regards °pa
I want a nest thermostat to control my heating but the heating system needs to understand opentherm.
Hello Pak0,
currently there is no way to control Vitodens 200 only with an Open-Therm thermostat. For your application, you can use the Vitotrol 100 to control the room temperature.
Kind regard °pa
What I basically want is a smart thermostat that knows when I am away to make my heating smarter.
Is there any smart thermostat that is compatible with my setup?
For example you can use Viessmann Vitocomfort. >> http://www.viessmann.co.uk/en/residential-buildings/heating-systems-for-new-build/smart-home-system....
