ViCare app fault for Vitodens 050 25kw
The ViCare app no ​​longer correctly displays the temperature and humidity for a Vitodens 050 25kw gas boiler using a ViCare Thermostat sensor. I reset the sensor to factory settings, changed the battery, disconnected and reconnected it to the boiler...nothing changes. It only has this problem for the heating circuit, not for hot water or other sections.
This issue started this summer, last winter everything worked fine.
Is there a solution for this fault?
 Thank you
0 ANTWORTEN 0
