Good Day!
We successfully installed ViCare app on mobile phone to control our boiler Vitodens 100 w B1HF-25. And didn't find an option for time programming to heat the water. This option is introduced on Google Play ( with screenshots) , but actually - on mobile there is no timing option, the same as Normal/Eco heating mode (only Standard).
Please help, how to enable these options on Vicare mobile app (screenshots attached)
Hello @Sergio_Mr
Since the boiler control setting is constant operation with room temperature controller, unfortunately it does not have schedules, if you change it to weather-controlled with a temperature sensor outside, schedules for heating and preparation of domestic hot water will also appear in the ViCare app.
greetings
Hello @Sergio_Mr
greetings
| 16 | |
| 14 | |
| 8 | |
| 8 | |
| 5 |
