Hello,
I have a Vitotrol 200-e controller with an internal temperature sensor. The manual mentions the possibility of connecting an external room temperature sensor. I used some NTC 10kOhm I had at home to try it out. However, the controller only displays the temperature measured by the internal sensor.
I couldn't find where to switch the temperature sensor in the manual. Or should I use some other special sensor.
Hello @kalistak
This is how you start the Vitotrol 200-E in configuration mode
then select that you have an external room temperature sensor and confirm
Greetings
Hello @kalistak
You connected the sensor correctly.
It is necessary to read the entire instructions.
Greetings
Thank you, I did not noticed. However I am not sure about that... Shall I do commissioning the system with the Commissioning Assistant ? Will be the previous commissioning setting lost ??
Hello @kalistak
Greetings
| 18 | |
| 9 | |
