Vitodens 100-W B1HF-32 equithermal control
Hello,
I have Vitodens 100-W B1HF-32 with installed external temperature sensor and the Vitotrol 200-e with room temperature sensor. The equithermal control is active. At night, the required reduced room temperature is set to 18 °C by the time program. The current room temperature is higher e.g. 20 °C, but the Vitodens is heating. Outside temperature is e.g 0°C.
I would like to know if the control algorithm takes into account the room temperature or how does the system work ?
Regards
0 ANTWORTEN 0
