[Vitocal 111-S] Looking for automated floor heating solution
Hello everyone,
currently at my home I've installed Vitocal 111-S heat pump for floor heating. It works fine over Vicare app, but the problem is that I can't find solution to control each room temperature. My goal is to control each room temperature over Vicare app.
I've found that Viessmann has to offer thermal valves (7750202) and Vicare climate sensor (ZK03839) but the problem is that I can't find controller part number. So my question is what kind of controller I can use and will it work with Vicare climate sensor and thermal valves over vicare app?
Hello Saulius,
for that please contact our collegaues at your country.
The thing is, that the ViCare-Smart-Climate-System is not available in every country.
Our collegaues at your country can tell you more about this, for your country.
Best wishes Benjamin from the Customer-Care-Team
Is it possible that they can only offer other brand solution instead viessmann?
Hello,
Try to run the system in the first winter with all valves open, without any actuator.
First adjust the heating curve in the next few month.
Then you can do some fine tuning with the flow meters.
You will need the actuators on for rooms with external heat e.g. sun.
BR
