Hello,
I am using right now Vitotrol app, with VitoCOM 100. What should I do to be able to use ViCare? Are there any advantages of ViCare over Vitotrol? I find the Vitotrol app quite out of the date.
Thanks,
Artur
Hello @amgajda
with the new Vitoconnect Opto2 and the ViCare App you can use singleroom control for example. ViCare is the future.
Best regards, Christoph
Hello,
can you list all advantages and disadvantages for me for changing vitocom100 into vitoconnect100, and pros and cons of vicare against vitotrol? I made some research and people report that there are no benefits whatsoever. I do like that vitocom100 connects via LAN, I do not have wifi in the heat pump room.
Thanks!
Artur
Hello @amgajda
if you have a strong Wifi in your room where your Heatpump is installed and also a free socket, you only have to buy the opto 2. The benefit you have with opto2 is already listed in my first post. At this time there is no great step between functions of Vitotrol App and ViCare. But ViCare will get future functions, Vitotrol don't.
| 7 | |
| 7 | |
| 6 | |
| 6 | |
| 4 |
