Hello,
[apologies for my English, but I don't speak German, and this looks like the right place to ask this question]
You can use Vitocal 200-G Wärmepumpe for heating.
You can add NC-BOX to provide cooling *AND* push heat into the ground in summer
You can use SunMaxx PVT-Module to generate electricity AND heat in summer.
But you need heat in winter!
Can you...
By cooling the SunMaxx PVT-Module, it produces 10-20% more electricity.
In winter, there is low solar electricity, and you don't want to use it all on wärmepumpe. But because the ground loop is high temperature, it uses much less electricity.
I see Vitocal 200-G Wärmepumpe can use ground loop up to 25C. This should be enough?
[I am not a heat engineer!]
I am trying to understand if this is a good design.
Hello anwarmahmood,
it won't work like that, because the soil also cools down naturally.
Many greetings
9 | |
4 |
