Correct setting for dip switch Vitovent 300-W
Hello
Out technician replaced the motherboard for Vitovent 300-W as I described in https://community.viessmann.de/t5/Lueftung/Vitovent-300-W-not-working-with-fully-functionality/m-p/3... but then I forgot to post the requested information.
Currently the LB1 panel shows that the maximum is 325m3/h even if the system can go up to 400m3/h. The technician didn't get any documentation, where the dip switch values described, all set to zeros by default.
What is the correct configuration?
Thanks,
Tamas
238D7611-5D01-4F5B-8E47-5619E07EF027_1_105_c.jpeg19601CEE-C133-4AD3-9E0C-98078ADA7E7E_1_105_c.jpeg
Hello Tamas,
I have answered you about this under your other post.
Best regards
