Hi there,
I connected my boiler with Vitogate 200 KNX to my intelligent instalation. In ETS on Viessmann plugin i clicked to Record system configuration button, but the plugin find an unsuitable boiler. When I try to add my boiler type with the add device control unit button (VDens HO1 is the correct type) there is no possibility to chose solar module SM1. The device data was updated to 5.4.22.
Another problem I noticed as soon as I connected the boiler with the vitogate he started showing an error message 98, (Solar module: open circuit sensor 7). In SM1 is used just a 5 and 6 the 7 and 10 is empty.
Could you advise me?
Thank you.
Hello Vandit,
in our community we only support in German and only heating systems and components which are produced for the German market. If you need support in your native language or support for a system which is not produced for the German market, please tell us where you are from an we will give you the contact details of our competent colleagues in your region.
Greeting Benjamin from the Customer-Care-Team
Hello Benjamin, i am from Slovakia.
