Vitodens 100 w B1HF-25 ViCare app have no time programming option for heating or hot water. ViCare app verison 3.26.1 (dwonloaded from Google Play)
Good Day!
We successfully installed ViCare app on mobile phone to control our boiler Vitodens 100 w B1HF-25. And didn't find an option for time programming to heat the water. This option is introduced on Google Play ( with screenshots) , but actually - on mobile there is no timing option, the same as Normal/Eco heating mode (only Standard).
Please help, how to enable these options on Vicare mobile app (screenshots attached)
Hello @Sergio_Mr
Since the boiler control setting is constant operation with room temperature controller, unfortunately it does not have schedules, if you change it to weather-controlled with a temperature sensor outside, schedules for heating and preparation of domestic hot water will also appear in the ViCare app.
greetings
Hello @Sergio_Mr
greetings
