Hello, does anyone knows if it is possible to change a boiler mode (OFF, DHW only, DHW and Heating) throught Vitogate 200? I only found data point for for changing modes in heating circuits (HK1, HK2, HK3. )
My system is
Vitodens 200-W
B2HA (weather compensated controls)
Vitogate 7452573
gira Homeserver (with Viessmann boiler App)
many thanks in advance
Hello,
if you change the heating mode in all heating circuits to 0=Abschaltbetrieb, DHW should be deaktivated.
Otherwise you can set down the dhw-temperature at KNX-DPT 9.001
For details look here
Heizing
You can set at KNX-DPT 255.004
heating circuit M2 at 0x3500(Technical ID)
and M3 at 0x4500
A1 at KNX-DPT 255.002 0x2323
You have to check if choosing "Abschaltbetrieb" only at A1 is enough. I am not sure.
You can't set DHW to 0, you can set the temperature vom 10 - 60 °C and when coding 56 : 1 is set from 10 - 90 °C . Maybe this coding can help for the temperatureproblem with your homeserver. When you want tot turn off, set to 10°C, then the boiler is off.
@Flo_Schneider Habt ihr in Bezug auf die 55°C beim Homeserver noch eine Idee?
Many greatings
Heizing
16 | |
2 |
