vitocal 300-G KNX
Hello,
I have a Vitcoal 300-G  with vitotronic 200 , in the different rooms I have temperature sensors in light switches (KNX).
wich is the best way to connect them? I don't have viessmann thermostat in the rooms . My Viessmann installer and electrician don't know the solutions 🙈 . Can you give me some advice how to fix it . My home automation runs ons KNX.  Everything (house) is brand new 2023
ps : you may answer in German (google translate will do the rest 😄 )
best regards from Belgium
3 ANTWORTEN 3
Hello HNBELG,
what exactly do you want to do?
Best regards
Hello Flo ,
this is the installation , normally it has to connect with my KNX system
so that I can set the temperature in every room
with this system i can only set the temperature for complete level of house
You need room thermostats that can be integrated via KNX. These control the control valves of your underfloor heating manifold. You can use a corresponding Vitogate KNX to control the heat pump and thus influence the room setpoint temperature.
Best regards
