Hello,
can I write my issue in english?
I have problem with Heizung (Vitocal 222), if I set the temperature for heizung (for example 50deg. - see in the picture), buffer tank heats up only for +-30deg and then the pump is switch off.
I am completed check service menu with manual and I did not found the mistake, or wrong settings. Can someone help me? Regards, Ota, Czech. rep.
Hello ota,
did you change any configuration of the control unit before this disfunction was given?
Please tell me your actual configuration of the following parameters:
Codieradress 7200, 7202, 7204, 7208
Did you configure a "Festwert" Timeprogram for the heating?
Best regards, °ch
| 17 | |
| 3 |
