any ideas as to why my heizung is knocking out my electric ...vitotronic 200..........so soon as it turns on it turns off my electric......
1 ANTWORT 1
Depends on what "knocking out" means. If a (main) fuse has triggered: Most probably some part of the heating electric causes a short circuit or, if available, triggers the RCCB; e.g. because of a water leakage. You will need an expert to check this (incl. your house's electric) asap.
