Hello,i have Viessmann 200-S and VitoConnect 100 opto1. I tried install Vitotrol Plus App on Android, but unsucessfully. I have problem with "create access".
On the end of wizard, when i check "licensing terms" and click on "Register", application stop working with message "Unfortunately, Vitotrol Plus has stopped". The same thing happened on my other phone (Android)
Can someone help me to fix it?
Regards,
DRagan
Die Vitotrol wird nicht mehr unterstützt. Du musst daher auf die ViCare ausweichen.
Übersetzt mit Google:
The Vitotrol is no longer supported. You must therefore switch to the ViCare.
