Also irgendwie scheint die API nach dem großen Ausfall kaputt zu sein, bitte prüfen:
Homeassistant API Abfragen klappt immer noch nicht.
#2024-01-11 21:01:39.100 DEBUG (MainThread) [homeassistant.components.vicare] Setting up ViCare component
2024-01-11 21:01:39.470 INFO (SyncWorker_8) [homeassistant.components.vicare] Found device: Heatbox1 (online: True)
2024-01-11 21:01:39.471 INFO (SyncWorker_8) [homeassistant.components.vicare] Found device: V300KW3 (online: True)
2024-01-11 21:01:39.504 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported solar_pump_active: 'Gateway' object has no attribute 'getSolarPumpActive'
2024-01-11 21:01:39.504 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported charging_active: 'Gateway' object has no attribute 'getDomesticHotWaterChargingActive'
2024-01-11 21:01:39.504 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported dhw_circulationpump_active: 'Gateway' object has no attribute 'getDomesticHotWaterCirculationPumpActive'
2024-01-11 21:01:39.505 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported dhw_pump_active: 'Gateway' object has no attribute 'getDomesticHotWaterPumpActive'
2024-01-11 21:01:39.505 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] No circuits found: 'Gateway' object has no attribute 'circuits'
2024-01-11 21:01:39.508 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] No burners found: 'Gateway' object has no attribute 'burners'
2024-01-11 21:01:39.508 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] No compressors found: 'Gateway' object has no attribute 'compressors'
2024-01-11 21:01:39.509 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported activate_onetimecharge: 'Gateway' object has no attribute 'getOneTimeCharge'
2024-01-11 21:01:39.509 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] No circuits found: 'Gateway' object has no attribute 'circuits'
2024-01-11 21:01:39.510 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported outside_temperature: 'Gateway' object has no attribute 'getOutsideTemperature'
2024-01-11 21:01:39.510 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported return_temperature: 'Gateway' object has no attribute 'getReturnTemperature'
2024-01-11 21:01:39.511 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported boiler_temperature: 'Gateway' object has no attribute 'getBoilerTemperature'
2024-01-11 21:01:39.511 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported boiler_supply_temperature: 'Gateway' object has no attribute 'getBoilerCommonSupplyTemperature'
2024-01-11 21:01:39.511 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported primary_circuit_supply_temperature: 'Gateway' object has no attribute 'getSupplyTemperaturePrimaryCircuit'
2024-01-11 21:01:39.511 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported primary_circuit_return_temperature: 'Gateway' object has no attribute 'getReturnTemperaturePrimaryCircuit'
2024-01-11 21:01:39.511 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported secondary_circuit_supply_temperature: 'Gateway' object has no attribute 'getSupplyTemperatureSecondaryCircuit'
2024-01-11 21:01:39.512 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported secondary_circuit_return_temperature: 'Gateway' object has no attribute 'getReturnTemperatureSecondaryCircuit'
2024-01-11 21:01:39.512 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported hotwater_out_temperature: 'Gateway' object has no attribute 'getDomesticHotWaterOutletTemperature'
2024-01-11 21:01:39.512 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported hotwater_max_temperature: 'Gateway' object has no attribute 'getDomesticHotWaterMaxTemperature'
2024-01-11 21:01:39.512 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported hotwater_min_temperature: 'Gateway' object has no attribute 'getDomesticHotWaterMinTemperature'
2024-01-11 21:01:39.512 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported hotwater_gas_consumption_today: 'Gateway' object has no attribute 'getGasConsumptionDomesticHotWaterToday'
2024-01-11 21:01:39.513 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported hotwater_gas_consumption_heating_this_week: 'Gateway' object has no attribute 'getGasConsumptionDomesticHotWaterThisWeek'
2024-01-11 21:01:39.513 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported hotwater_gas_consumption_heating_this_month: 'Gateway' object has no attribute 'getGasConsumptionDomesticHotWaterThisMonth'
2024-01-11 21:01:39.513 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported hotwater_gas_consumption_heating_this_year: 'Gateway' object has no attribute 'getGasConsumptionDomesticHotWaterThisYear'
2024-01-11 21:01:39.513 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported gas_consumption_heating_today: 'Gateway' object has no attribute 'getGasConsumptionHeatingToday'
2024-01-11 21:01:39.513 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported gas_consumption_heating_this_week: 'Gateway' object has no attribute 'getGasConsumptionHeatingThisWeek'
2024-01-11 21:01:39.513 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported gas_consumption_heating_this_month: 'Gateway' object has no attribute 'getGasConsumptionHeatingThisMonth'
2024-01-11 21:01:39.514 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported gas_consumption_heating_this_year: 'Gateway' object has no attribute 'getGasConsumptionHeatingThisYear'
2024-01-11 21:01:39.514 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported gas_summary_consumption_heating_currentday: 'Gateway' object has no attribute 'getGasSummaryConsumptionHeatingCurrentDay'
2024-01-11 21:01:39.514 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported gas_summary_consumption_heating_currentmonth: 'Gateway' object has no attribute 'getGasSummaryConsumptionHeatingCurrentMonth'
2024-01-11 21:01:39.514 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported gas_summary_consumption_heating_currentyear: 'Gateway' object has no attribute 'getGasSummaryConsumptionHeatingCurrentYear'
2024-01-11 21:01:39.514 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported gas_summary_consumption_heating_lastsevendays: 'Gateway' object has no attribute 'getGasSummaryConsumptionHeatingLastSevenDays'
2024-01-11 21:01:39.515 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported hotwater_gas_summary_consumption_heating_currentday: 'Gateway' object has no attribute 'getGasSummaryConsumptionDomesticHotWaterCurrentDay'
2024-01-11 21:01:39.515 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported hotwater_gas_summary_consumption_heating_currentmonth: 'Gateway' object has no attribute 'getGasSummaryConsumptionDomesticHotWaterCurrentMonth'
2024-01-11 21:01:39.520 DEBUG (SyncWorker_5) [homeassistant.components.vicare.utils] No circuits found: 'Gateway' object has no attribute 'circuits'
2024-01-11 21:01:39.515 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported hotwater_gas_summary_consumption_heating_currentyear: 'Gateway' object has no attribute 'getGasSummaryConsumptionDomesticHotWaterCurrentYear'
2024-01-11 21:01:39.527 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported hotwater_gas_summary_consumption_heating_lastsevendays: 'Gateway' object has no attribute 'getGasSummaryConsumptionDomesticHotWaterLastSevenDays'
2024-01-11 21:01:39.528 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported energy_summary_consumption_heating_currentday: 'Gateway' object has no attribute 'getPowerSummaryConsumptionHeatingCurrentDay'
2024-01-11 21:01:39.528 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported energy_summary_consumption_heating_currentmonth: 'Gateway' object has no attribute 'getPowerSummaryConsumptionHeatingCurrentMonth'
2024-01-11 21:01:39.528 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported energy_summary_consumption_heating_currentyear: 'Gateway' object has no attribute 'getPowerSummaryConsumptionHeatingCurrentYear'
2024-01-11 21:01:39.528 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported energy_summary_consumption_heating_lastsevendays: 'Gateway' object has no attribute 'getPowerSummaryConsumptionHeatingLastSevenDays'
2024-01-11 21:01:39.528 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported energy_dhw_summary_consumption_heating_currentday: 'Gateway' object has no attribute 'getPowerSummaryConsumptionDomesticHotWaterCurrentDay'
2024-01-11 21:01:39.529 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported energy_dhw_summary_consumption_heating_currentmonth: 'Gateway' object has no attribute 'getPowerSummaryConsumptionDomesticHotWaterCurrentMonth'
2024-01-11 21:01:39.529 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported energy_dhw_summary_consumption_heating_currentyear: 'Gateway' object has no attribute 'getPowerSummaryConsumptionDomesticHotWaterCurrentYear'
2024-01-11 21:01:39.529 DEBUG (SyncWorker_6) [homeassistant.components.vicare.utils] Feature not supported energy_summary_dhw_consumption_heating_lastsevendays: 'Gateway' object has no attribute 'getPowerSummaryConsumptionDomesticHotWaterLastSevenDays'
Habe auch das Problem mit Home Assistant. Log sieht genau so aus. Seit letzter Nacht, ca. 1 Uhr, keine Konnektivität.
Bei mir ebenso - seit dem Ausfall am 10.01. keine Verbindung mehr über homeassistant
und das Forum hat jetzt auch etwas 🙈
