Vitodens 300 / LAN / Vitotrol plus app
Hi
I live in Denmark and my German is not that good - so this question is in english 🙂
I've got a Vitodens 300 with lan interface (touch screen model)
I've got the lan interface up and running (got some firmware updated) and I got the vitotrol plus app installed on my Iphone (only avaliable in the german Itune store ?)
I did the registration (hersteller and ID) in the app which completed succesfully but when I log into the app I receive this "there is no system present supported by the vitotrol plus"
Can you please help me - what is wrong ?
Thank
Kind regards
Carsten
Hello Carsten,
please try again. Now there must be a connection!
Greetings °jo
7 ANTWORTEN 7
Hi Carsten,
the symbol for "LAN-Verbindung aktiv" has to be visible on the display of the control unit.
Also the option "Automatische Updates" has to be activated.
Is there a powerline adapter installed between your router and the control unit?
Greetings from Germany °jo
Hi Hansi,
I think everything is fine at my installation
The Vitodens 300 show lan connected in the display - I can see an ip address and i can ping the adress from my computer (192.168.0.x).
The automatic update is activated - I received and installed an update for the lan module
No - no powerline - the lan module is directly connected to my router.
Is there any way that you can check if my registration (is my serial/hersteller and ID correct) and it is registered with my login ?
I could mail this information to you if you provide me an email address 🙂
/Carsten
Hello Carsten,
please send your Login-Data and your password to Social-Media@Viessmann.com
Kind regards
°jo
Done !
Hello Carsten,
Greetings °jo
Perfect - its working 🙂
Thanks - just curious - what was wrong ?
There was a problem with our server! Everything you did was correct!
Greetings °jo
