Vitodens 111-W B1LF-25 - Adjusting water temperature in hot water cylinder
Hi Everyone,
Is there a way to adjust water temperature in the hot water cylinder separately? I can adjust the water temperature using the user interface menu but it seems that this does not adjust the water temp in the cylinder (it's much hotter then what I set up in the menu). Thank you!
0 ANTWORTEN 0
