Hello! I have a ViCare thermostat connected to a Viessmann Vitodens 100 B1KF 32 kw and sometimes something strange is happening. Even if the set temperature is reached the boiler continue to work for at least 1 celsius degree extra. For example i set temperature to 23 and the room temp is 23,6 and the boiler continue to heat the room. I attach a photo from ViCare app. Can i fix this overheating problem?
18 | |
8 | |
2 |
