Bad value in the Vitoguide
Hello,
Yesterday I tryed the new web Vitoguide and I have problem with Output temperature. It write error insted of value.
I have Vitodens 200W- B2HB - 7570775601562112
Can you check if is problem on my side ? Picure is for device switched in Czech language ...
undefined
Hello karel_cz,
everything is correctly.
The common flow temperature could only be displayed, if you have a hydraulic switch.
Greeting °be
1 ANTWORT 1
Hello karel_cz,
Greeting °be
