vitosolic 200 sd4 Function blocks output relay parallel connection
Hello,
Funcion blocks (FB) has several conditions which all have to be met to activate a relay . In other words it acts as AND operator.
Is it electrically allowed to conect FB outpur relays in parallel to have OR function ... For example our customer wants to have heating from cylinder  when original FB2 conditions met ( based on return and cylinder temp difference) OR cylinder temp is above 30 degrees
Hello KZ,
please contact Viessmann UK: [email protected]
Best regards °pa
Hello KZ,
Best regards °pa
