Dear community,
I'm owning a Viessmann Vitocal 200S Heatpump with two heating circuits (underfloor and ventilo's).
Connected to the heatpump is a Vitogate 200, KNX and a Vitoconnect WIFI module.
I'm still figuring out the best possible way to control every room independently through KNX, but to start I only want to control HC1 (ventilo's) with a KNX temperature sensor in the bathroom as room temperature feedback.
Therefore I do not use the Viessmann Vitotrol 200 to control the circuit.
The issue I have: I cannot write to the room temperature datapoint?
As you can see in the screenshot from ETS6, the datapoint is Read only.
So my question is: can I change this to Read/Write?
And, can I use the heating circuit without Vitotrol 200?
Another issue I have developing this: I couldn't find any contact at Viessmann who could deliver my the datapoint documentation?
Best regards,
Niels Steyaert
Hello nielssteyaert,
in our community we only support in German and only heating systems and components which are produced for the German market. If you need support in your native language or support for a system which is not produced for the German market, please tell us where you are from an we will give you the contact details of our competent colleagues in your region.
Greeting Benjamin from the Customer-Care-Team
Hello Benjamin,
Thank you for your answer.
I'm located in Belgium, Gent.
Best regards,
Niels
Please use the following contact informations.
