Vitovent 300-W not working with fully functionality
Hello!
I have a Vitovent 300-W H32S C400, it has been installed during last November into our family house. At the beginning of February an error message popped up during the evening, which stated that an exhaust fan issue. I contacted our supplier, they:
1 - replaced the fan - issue remained
2 - replaced the other fan - issue remained
3 - replaced the motherboard - issue remained
4 - motherboard has been configured somehow - issue disappeared, both fans started to work but in the LB1 overview section it showed zeros, so the values were zeros and it does not saw what the system does, after three days it stopped again with the same issue.
5 - changed again everything (fans, motherboard) - currently it seems to working but the values are still zeros, the "Set room temperature" menu point disappeared and the system does not rely on LB1 config so it runs in full power even on the 1st, lowest level but it's strange because only the blow in part, the exhast is seems to be stopped.
If I attach pictures, is it possible to check the motherboard configuration? There are different, very smal switches.
On the other hand, is it worth to connect it to a Vitocal 200-s heat pump?
Thanks!
15 ANTWORTEN 15
Hello tmsblgh,
you are welcome to attach pictures. Also let me know the serial number of the Vitovent.
Many greetings
Hello @Flo_Schneider,
Sorry for the late reply, I waited for the company. So here are the pictures:
19601CEE-C133-4AD3-9E0C-98078ADA7E7E_1_102_o.jpeg238D7611-5D01-4F5B-8E47-5619E07EF027.jpg
I see that there is a dip-switch on the middle of the motherboard. What should be the correct setting for the C400 model?
Best regards,
Tamas
Hello Tamas,
the dip switches remain as delivered and are not changed.
It is important that the C1FE and C1FD parameters are set correctly after installation. This is because this setting can no longer be changed afterwards.
Best regards
Sounds bad, I see only C1FD in the service/hidden menu with -1 value.
Best regards,
Tamas
Has something already been set here or has this not yet happened? Can you make a setting?
Best regards
Nothing from my side and I think the technician didn't know about this... I cannot, -1 is the only option.
Best regards,
Tamas
What about C1FE?
Best regards
It is not visible on first level of service. Is it in 2nd level?
Tamas
Have a look. Do you know how to get in there?
Best regards
No, I guess there is a code for that. We have a Vitocal 200-s and in a separate thread you wrote the "enter code" to reach 2nd level. 🙂
Tamas
Try out whether this also works with the LB1. In the service level, press the OK and menu buttons simultaneously for approx. 4 seconds. Then enter the code 3442541331.
Best regards
Thanks, I was able to enter level 2 but with the back & OK buttons. I still don't see C1FE, only C1DE with possible values from 0 to 3.
Best regards,
Tamas
OK, normally both should be visible. Please contact the branch in your country again.
Best regards
Dear Flo,
I have a similar problem of tmsblgh with a vitovent 300-w c325.
All the problems started with error E1 in the LB1 and at this point i was unable to set the full speed or make others change because the LB1 crash every time.
The technician started changed the motherboard but the problem still persist…then they replace LB1 and now the error E1 disappeared.
But i noted that the vitovent works at full power and in the menu is not available the “nominal ambient temperature”: i found this post and i checked the service menu and the C1FE is set to -1…the technician did not configure the system? what i have to set now? 32 or 33? C1FD avalable in the service level 2 is set -1 with no other value available.
thanks
Hello @damiii & @Flo_Schneider,
Few months back, the technician replaced the motherboard again. With the new board we were able to see C1FE, but when we set code 35 (for 400m3/h and right setup) and pushed the OK button, it stored only for 3 seconds, then it returned to 50 (if I recall correctly). So we were not able to set it somehow.
C1FE was not available at that time, it was not visible.
Strange...
