Hi, I recently had a Vitoden 050-W 30kW Combi boiler installed and the timing on the system is an hour wrong, I am having to set the heating an hour later so it comes on when I need it too. How do I put this right? I'd have thought as it is connected to the wi-fi, it would correct itself however it has now been like this for 2 months :(.
So to clarify, if I want my heating on at 7am, I have to set the timer for 8am and for it to go off at 10pm, timer is set at 9pm.
Hello!
I encountered the same problem on a Vitodens 100. I also expected it to be synchronized via the Internet. But it seems not.
I solved the problem by setting the date and time directly from the boiler.
See how to do it in the boiler's documentation.
Sebastian Vlaicu
Thanks for the advise however in the 050-W operation instructions there is no info on this topic. My engineer who installed it says it needs to be put into engineer mode, he has since said a Viessmann engineer should be able to dial in remotely to correct the problem. I will look at the installation details tonight to see if there is anything in there.
