Hello, I have a Vitodens 200 (WB2) with BEM controller, which I would like to connect to Tado systems.
https://www.tado.com/de-en/wireless-smart-thermostat
Tado tells me that the BEM is not compatible with Tado. How can I make my Viessman Vitodens 200 compatible with Tado ?
Thank you !
Hi Leonard, have you found a solution to connect the tado with the boiler? I have the same issue.
Thank you.
Hi SKOP,
Unfortunately not yet. Haven't looked much in the past month.
