Guten Tag liebes Team,
ich lese über die Viessmann API diverse Meldungen aus. Was mir aufgefallen ist, das der Punkt device.message.logbook beim Starten der Wärmepumpe immer ein Fehlereintrag ersichtlich ist, der nicht in der Viessmann oder als Fehler im Kältekreisregler erscheint:
[{"timestamp":"2026-06-22T18:16:55.000Z","actor":"VERDICHTER1","status":26,"event":"Inverter_DCbus_ripple","circuit":"K\u00fchlkreis","stateMachine":"WAERMEPUMPE1","additionalInfo":182},{"timestamp":"2026-06-22T18:14:55.000Z","actor":"PRIMAERQUELLE1","status":100,"event":"PRIMARY_IN","circuit":"K\u00fchlkreis","stateMachine":"WAERMEPUMPE1","additionalInfo":120},
{"timestamp":"2026-06-21T15:04:07.000Z","actor":"SEK_PUMPE1","status":0,"event":"Inverter_CPU_error","stateMachine":"TPM_SC2","additionalInfo":120},{"timestamp":"2026-06-21T15:02:11.000Z","actor":"SEK_PUMPE1","status":100,"event":"Evap_SuctGas_T emp","stateMachine":"TPM_SC2","additionalInfo":117},{"timestamp":"2026-06-21T13:39:20.000Z","actor":"VERDICHTER1","status":0,"event":"PRIMARY_OUT","circuit":"K\u00fchlkreis","stateMachine":"WAERMEPUMPE1","additionalInfo":180}]
Hättet Ihr eine Info zu den Einträgen?
Danke euch,
lg Michael
