"Diese Komponente wurde bereits registriert." - durch Vorbesitzer
Hello,
 I moved into an apartment with an existing Viessmann gas boiler. Unfortunately, I cannot connect the boiler to the ViCare app, as it indicates that the component is already registered.
Apparently there is no way to contact Viessmann service directly, so I am reluctantly submitting my request this way, asking for help in removing the old link.
Hier ist die Seriennummer meines Geräts: 7632995108376120
Thank you in advance and best regards
1 ANTWORT 1
@CustomerCareChris can you or one of your colleagues help please ?
