Hello,
Since the update to 3.0 i cannot see anymore when a device is active.
For example when setting the wanted temperature higher than the actual temperature befor there was a orange circle that indicated that the pump was on.
Same for the Tap water.
Since the update i didnt have this visible anymore what i find not very handy.
Is this a setting that i need to change ? I have searched but didnt find this.
I have a Vitodens 222-W with the OPTO1 coupler so maybe it has something to do with the combination ? But before i had this visible and since the interface is only change to a modern look i asume that this option must be there.
Thanks
Dcaub
Hi Dcaub,
you're right. The "orange circle" isn't supported any longer since version 3.0.0. Nevertheless, you can see whether a pump is running or not by clicking on "Settings" (Einstellungen) and then select "Device status" (Gerätestatus). There you can also see whether the burner is running or not.
Have a nice day and stay healthy, Thomas
Hello,
Thanks for reaction.
Stupid that they have deleted this option without any warning the update is automaticly and suddenly you lose a function.
For me it is just a new moderner look and less in function.
The weather forecast is a option that i didnt need for me the actual outside temperature is more interesting than the one of the weather forecast wich is not Always the correct one.
Is there a way to go back to the version before do you know that ?
If i had now it before i would not have done the update to 3.0
Why they left this out ? They could set even easy a option if you want to see it.
Not client friendly . When you do a update you dont leave functions out without notice for it.
Viessmann bad points !
Thanks
Dcaub
| 12 | |
| 11 | |
| 5 |
