Hi,
last week I had a situation where the date/time setting of my heating went completely wrong, something similar to Probleme mit Einstellungen und Verlaufsdaten seit ... - Viessmann Community (viessmann-community.com... which is also very recent.
It took me sometime to figure out that the reason for the cold water was the wrong date-time in my heating system. This was probably caused by a power out problem we had in the region 2 days before. The system is around 5 years old and had other power out cases in the past without loosing the date/time setting, but not this time. I manually entered the correct values in the touch panel and everything is working fine since then.
My question here to the community and Viessmann support:
is there a way in the API to (1) read the current date/time setting in the heating system (2) set a new date/time (3) synchronize it with an NTP server?
Thanks in advance for your support!
Ah - i was wrong about the heater generation. Yours is younger and this battery is really diffrent... 😉
Maybe this is also a smaller lithium - type, but i´m not absolutely sure.
14 | |
11 | |
9 | |
