Climate sensor supplied with Vitoden 100
It is unfortunate that English is  not available as an option on this platform. A Vitoden 100 with climate sensor was commissioned recently in my flat and I am very disappointed to learn that the climate sensor
1. Does not stop the boiler even after the set temp is reached and it overheats the room.  the problem was reported in 2021 on this forum which was answered by the company that a fix was underway. The basic function of a thermostat is not fulfilled. How is this "smart"
2. The heating system water temperature went up to 90 deg and I could not change or control it even on the operating panel of the boiler. Many other functions which are talked about in the manual like P1 P3 P4 P5 are just now available. I want to run the boiler colder to minimise salt deposit
3. The flue gas temperature is very high i.e more than 50 deg for a condensing boiler . where is the efficiency claim when so much energy is wasted to the outside.
4. Most frustrating is that if there is no wifi in the house, there is no control possible. The thermostat has no user interface to control the boiler. design of an automatic system with no business continuity plan  for IT failure??
I would not recommend this sensor to anyone based on this limited experience.
0 ANTWORTEN 0
