Hello!
I have an Vitocal 333-g with Vitotronic 200 control. The system is configured with two heat circuits, one for the basement (under ground =HC1) and one for the rest of the house (=HC2) where we live.
As of now both external circulation pumps stops when outside temperature is "indoor setpoint temperature minus 4 degrees" (21-4=17). This is ok for HC2 but how may I by configuration force the circulation pump for HC1 (basement) to run all year around? I need some heat there to keep the moist away.
I don't want to connect the circulation pump (HC1) with external/separate power since I want to be able to shut down the whole system by unpowering the Vitocal with its power button.
Happy if you could guide me how to configure continuous circulation in one of two heat circuits! Thanks!
Hi Vantive,
the heatpump of circuit one is in a mode called antifreeze. At lower outside
temperatures, it is quite normal that this heatpump is turnig all the time.
Best regards, °ch
| 17 | |
| 3 |
