Vitodens 333 communication
Hello,
sorry for the English, but I'm from Italy and don't speak Deutsch....
I have a Vitodens 333 with NO remote (at the moment), and a KNX system in the house.
I would like to get some informations about the boiler/heater and eventually command it.
- which "remote" can I connect to it? Can I use "normale" FS17 cables (electric wires, 1,5mmq each) from the heater to the remote (2 floors of difference..)?
- which is the cheapest way to connect the heater to my KNX system? Any incompability with point 1?
- if above is not possible, any idea to avoid checking everytime to the bolier room downstairs?
Thanks in advance,
Luca
5 ANTWORTEN 5
Hello brusuillis,
to connect your Vitodens 333 to your KNX system, you need a Vitogate 200 KNX. Information about this system you´ll find under the following link:
https://connectivity.viessmann.com/uk/mp_rt/vitogate-info.html
Beste wishes °be
SO, if I buy the Vitogate 200 KNX, no other module needed?
For the other question: is the Vitotrol 200A or 300A compatible with my heater?
And the Vitocom 100?
Those would obviously not connect to KNX but will let me manage the heater from INSIDE the apartment, right?
Yes, you only need the Vitogate 200 KNX.
To check the compatibility to the Vitotrol 200A, 300A and the Vitocom 100 LAN1 I need the serialnumber of your Vitodens 333.
With the Vitotrol 200A and 300A you can manage your system from inside of the apartment. With the Vitocom 100 LAN1 you can manage your system from all over the world, with an App or with your browser (https://vitodata100.viessmann.com/VD100/VD100/Login/Login.aspx).
Best wishes °be
Hi, serial is 7177362410577108
Thanks
Thank you for the serialnumber. Your Vitodens 333 is not compatible to the Vitotrol 200A or 300A.
Best wishes °be
