Program of boiler
Boiler has Normal and Reduced settings for timing bu not an “Off” setting under the program.
this could be very helpful as I don’t always want Normal or Reduced.   Sometimes I want it Off.   (Even if it were overrun by the anti frost setting).
csn this be an improvement for the next app update ?
Please use the following link.
https://www.viessmann.co.uk/contact
6 ANTWORTEN 6
Hello MauroCarneiro,
in our community we only support in German and only heating systems and components which are produced for the German market. If you need support in your native language or support for a system which is not produced for the German market, please tell us where you are from an we will give you the contact details of our competent colleagues in your region.
Greeting Benjamin from the Customer-Care-Team
Der Boiler hat normale und reduzierte Einstellungen für das Timing, aber keine „Aus“-Einstellung unter dem Programm. Dies könnte sehr hilfreich sein, da ich nicht immer Normal oder Reduziert möchte. Manchmal möchte ich es aus. (Auch wenn es von der Anti-Frost-Einstellung überfahren wurde). Kann das eine Verbesserung für das nächste App-Update sein?
I am based in the United Kingdom.   And have a nice system installed with two separate pumps as well.
