Hot water not available
Hello,
suddenly yesterday my Vitodens 300 stopped providing hot water.
Boiler have no error, Vicare app shows 48° as setting and 23° as actual water temperature, everything seems working.
Where should I start from?
Thanks
8 ANTWORTEN 8
Hello brusuillis,
please give me the serial number of the Vitodens.
Kind regards °ja
Thanks
Update: pump is running, but burner does not ignite even if I request hot water
Thanks. Please check adress 38.
Kind regards °ja
Code 38: 33
Thank´s. The value 33 states that there is an internal undervoltage. In this case, the control unit must be replaced.
Kind regards °ja
Unfortunately you are right. Time to move to a new unit..
Thanks for the answers
No Problem. 😉
Kind regards °ja
