Google Home Assistant improvement request.
In recent days I succeeded in connecting my Viessmann account to Google Home.
I can now change the setpoint of my Vitodens 100-W boiler, but I'd like to be able to change its mode, that is changing it from HEAT to ECO and back.
Using the recent possibility to write routines in YAML language in Google Home, I tried to do that, but the only available command is HEAT:
Could you please also add the possibility to select the ECHO or maybe OFF mode for the home temperature control?
Tnak you!
Marco
0 ANTWORTEN 0
