Dear
For 3 radiators (bed room) I have installed ViCare thermostats. These thermostats are linked to the radiators. Besides the radiators, we have floor heating which works indepently from the radiators (2 different pumps).
As you can see on the screenshot, all rooms are in standby (mode 1) and have similar time schedule. One room is constantly at about 19.5°C (Slaapkamer Paulette). I have already changed the thermostat in this room by a new one, because I thought it was faulty. The type of radiators are all the same, and have the same age.
Given the fact that the pump for these ViCare thermostats (radiator pump) is constantly on, this radiator heats up all the time.
Two questions;
- is there a way to not have the radiator pump on all the time - but only when there is a heat request (acc to schedule)?
- what could be the reason this thermostats keeps on 'leaking'? How can I test this is linked to the radiator?
Thanks a lot
| 11 | |
| 10 | |
| 5 |
