Hello,
first of all, sorry for writing in English but I can't speak German.
My electrician installed 3 Vitovent 100-D, and provided the controller in the photo.
I can't use the app as I can create the mesh system with the 3 fans and the controller (they work together flawlessly or at least it seems) but it can't be synchronized as a "command" in Vitovent-d App.
In the manual it's supposed to be done entering the configuration button of the app and then pressing the up and down arrows in the same time, but even waiting the 10 seconds no light shows up.
I already had a look in the forum and if I didn't go wrong the wlan connection can be obtained just with the wired controller and this one they gave me should be used just as "secondary" button. Is it ?
I'm getting mad as the electrician is not able of obtaining more support from his seller.
Thanks in advance with any additional info,
Hello Ric_Vice,
The reason for you not being able to adjust settings of the shown control unit is that it is doesn't support Vitovent D app control.
There are three types of wireless control units for Vitovent 100-D H40E B55 (F) with different spectrum of functionalities:
And FIY: Right now there is no algorhithm on the mainboards of the 100-D H40E B55 (F) control units of fans to auto-adjust the air volume flow when an uneven numebr of fans is installed (this feature is only supported with the cable system right now). As a result you will have a disbalance of exhaust and supply air. It is not that critical but I just wanted to let you know.
Best Regards
