Enable/Disable electric heating support
Hello all,
i have disabled heating with electro on my 200-S. Is it possible to activate it via the api?
I do not need the support of electric heating, but in some cases i want to heat up faster with the support of the electric heating.
Edit: Oh and ist heating.dhw.charging the endpoint for the check if electric heating support is on?
Thanks for your help
Matthias
Hi @mpateck ,
The electric heating of your heat pump cannot be controlled via the public API currently.
The feature heating.dhw.charging which you are mentioning shows whether the hot water charging in DHW storage is active. This is however independently of the electric heating.
I hope the clarification helps.
Regards,
MIchael
2 ANTWORTEN 2
Hi @mpateck ,
Regards,
MIchael
Hello Michael,
thank you for the explanation.
Matthias
