heating.power.consumption.{dhw,heating,total} invalid date ?
Hello,
When retrieving the API, data is either strange or not consistent. I will show for Total, but it is same on dhw and heating. I will concentrate on daily, just for limiting the explanation
We are, today, the 24-02-2025.
I receive this array of values: [0.3, 11, 10, 15.7, 25.000000000000004, 33.8, 32.6, 37.3].
DayValueReadAt is: 2025-02-22T14:41:51.317Z
So, if we follow the idea: 0.3 = 22/02/2025, 11 the 21/02, 10 the 20/02, 15.7 the 19/02, 25 the 18/02 etc...
But everything is shifted one day if we compare with ViCare: 0.3 = ???, 11 the 22/02, 10 the 21/02, 15.7 the 20/02, 25 the 19/02.
I feels also that, at one point, I received correct positionning. Because I have, on my system a check for new data with what the API provides. And it is also checking consistency, it is this pass which tell me that the "newly received data" is invalid with what I already received ! I, sadly, had not enabled logging on this part of code.
How can we fix it ?
3 ANTWORTEN 3
So, I have now improved logging. And it feels completely wrong. Not that I am in France (+1 tz).
On the 25/02, at 14:16:06,502 :
- array is: [ 9.2, 9.9, 17.799999999999997, 11, 10, 15.7, 25.000000000000004, 33.8]
- dayValueReadAt: 2025-02-25T13:13:57.206Z
THIS IS CORRECT! I drop the first element of the array as I don't care about "today". Consumption on vicare of the 24/02 is of 10kWh, and previous day are fine also (albeit, roundings)
On the 25/02 at 23:57:53,351:
- array is: [19.6, 19, 9.9, 17.799999999999997, 11, 10, 15.7, 25.000000000000004]
THIS IS WRONG! (my final consumption for the 25/02 on vicare is 19.5Kwh. So we have 2 glitches: wrong dayValueReadAt, wrong number of elements)
On the 25/02 at 23:59:54,196:
- array is: [0, 19, 9.9, 17.799999999999997, 11, 10, 15.7, 25.000000000000004]
THIS IS WRONG ! (Same as before, with a 0 in front...)
From this time the front value will improve according to the new day. This logic seems fine. But the dayValueReadAt stays as 2025-02-25T13:13:57.206Z !
On the 26/02 at 00:15:01:
- array is: [0.2, 19.6, 9.9, 17.799999999999997, 11, 10, 15.7, 25.000000000000004]
THIS IS WRONG! (values ​​look fine, but as the date is the wrong one, we will think it is the 24th which has a power of 19.6 while it is in fact the 9.9...)
[Story twist incoming, waiting for the data to come in. But actually the API is working perfectly fine between 14h30 and 23h50....]
Yes, does not work. Same Problem for me, the current day always just shows 0.x as a value, which is quiet unfortunate as the Viesmann App on Android works just fine.
This is also happening in ViGuide for "professional use", but there if you click on the diagram with the wrong data the correct one opens.
Has to be some issue with the api call.
So, I have now improved logging. And it feels completely wrong. Note that I am in France (+1 tz).
Feels like we are having multiple issues: dayValueReadAt never changes, possible duplication of data in the list etc...
