Hi,
at https://developer.viessmann.com/en/doc/iot/overview it is said that a simple GET request to https://api.viessmann.com/iot/v1/equipment/installations should return the installationId.
Everything I get is
{"data":[],"cursor":{"next":""}}
To query the API endpoint I'm using the small PHP script from https://www.viessmann-community.com/t5/Getting-started-programming-with/To-help-get-started/td-p/181... which shows me my user details.
I simply added the following at the end of the PHP script:
$url = "https://api.viessmann.com/iot/v1/equipment/installations/";
$curloptions = array(
CURLOPT_URL => $url,
CURLOPT_HTTPHEADER => $header,
CURLOPT_SSL_VERIFYPEER => false,
CURLOPT_RETURNTRANSFER => true,
//CURLOPT_HTTPAUTH => CURLAUTH_BASIC,
// Data Curl Call
$curl = curl_init();
curl_setopt_array($curl, $curloptions);
$response = curl_exec($curl);
curl_close($curl);
echo($response);
Am I missing something?
Cheers
Andreas
Hi @MrAnderson ,
This topic is related to the issue you stated in this thread right? https://www.viessmann-community.com/t5/Getting-started-programming-with/Some-code-to-receive-info-fr...
Solution was that the account you are using has no installation registered.
Best,
Michael
Hi, I get the same error message. But I do not use ViCare (Vitovalor 300p), only Vitodata300 and Vitotrol. Is there anyting else required to register my installation for data retrieval via the API?!
Thanks in advance.
@snigge for using the API for your device, your system must be connected through a Vitoconnect or using the connectivity inside the device (if available) and be registered using the ViCare app. Vitodata is unfortunately not compatible with the API.
Regards,
Michael
Hello,
I used this address to get installationId, gatewaySerial and deviceId:
https://api.viessmann.com/iot/v1/equipment/installations?includeGateways=true
What I get is JSON type data, such as installationId and gatewaySerial but there is no deviceId. 😞
Any advice?
Thank you.
I'm also having problems with the deviceId.
This is working:
https://api.viessmann.com/iot/v1/equipment/installations/{{installationID}}/gateways/{{gatewaySerial}}/devices
The deviceID result is like
id "gateway" or ""RoomControl-1" or "HeatDemandControl"
but these deviceIDs don'T work with https://api.viessmann.com/iot/v2/features/installations/{{installationId}}/gateways/{{gatewaySerial}}/devices/{{deviceId}}/features
viErrorId "req-e76ed613ba894480bca7cf2fe47a1a4d"
statusCode 502
errorType "EVEREST_ERROR"
message "EVEREST_ERROR"
extendedPayload
code "404"
reason "Client does not exist"
Please help, thanks.
Try deviceId=0
Hello Robinson. Error also with deviceId 0
viErrorId "req-fc7490aca1574c12a28a959aa1de2ed3"
statusCode 502
extendedPayload
code "404"
I think you are making the same error as me.
You can't just put this addrss in your browser. It won't work.
You need to use something like POSTMAN.
I have to learn it myself too.
Thank you, Robinson.
